Hello Guest it is October 22, 2026, 03:37:46 PM
Author Topic: MPG Signal requirements  (Read 13531 times)
Offline Sage
  •  370 370
« on: August 29, 2008, 08:51:48 AM »
Can someone confirm the signal requirements for Mach3 MPG inputs to a parallel port? I haven't been able to find it anywhere.
It looks like there are two signals required as the setup shows A and B signals.
Is a quadrature signal required or something else?
I'm asking becasue I came across a nice handwheel on a panel with a bunch of switches. The handwheel may already produce a quadrature signal. If not I'll make my own circuit to generate whatever is required.
Sage
Re: MPG Signal requirements
« Reply #1 on: August 29, 2008, 09:39:29 AM »
Sage,
    Yes, you need a quadrature signal.
Offline Sage
  •  370 370
« Reply #2 on: August 29, 2008, 09:50:04 AM »
Thanks. I'll see what I can cobble together.
Sage
