Hello
Guest
it is
November 28, 2026, 05:00:38 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
MPG Signal requirements
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: MPG Signal requirements (Read 13865 times)
Sage
370
on:
August 29, 2008, 08:51:48 AM »
Can someone confirm the signal requirements for Mach3 MPG inputs to a parallel port? I haven't been able to find it anywhere.
It looks like there are two signals required as the setup shows A and B signals.
Is a quadrature signal required or something else?
I'm asking becasue I came across a nice handwheel on a panel with a bunch of switches. The handwheel may already produce a quadrature signal. If not I'll make my own circuit to generate whatever is required.
Sage
Logged
HimyKabibble
1,687
Re: MPG Signal requirements
Reply #1 on:
August 29, 2008, 09:39:29 AM »
Sage,
Yes, you need a quadrature signal.
Logged
Sage
370
Reply #2 on:
August 29, 2008, 09:50:04 AM »
Thanks. I'll see what I can cobble together.
Sage
Logged
Print
Pages:
1
Go Up
« previous
next »
