Hello Guest it is September 05, 2026, 05:47:15 PM
Author Topic: How do I remove this out of the gcode  (Read 54861 times)
Re: How do I remove this out of the gcode
« Reply #10 on: August 25, 2008, 07:49:51 PM »
so did you remove the extra z movement manually or did you get that tap file straight from post code on lazy cam. If you got it to post from lazy cam like that what did you change.
David
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #11 on: August 25, 2008, 08:06:16 PM »
Hi, David
It's a modified .pst for LCam, It is just below the picture 2 posts back, Put it into c:\Mach3 folder , Then in LCam click on Post Code button, Then click on Set Post Processor Button, Find the "Mill Example 08 25 08 new A.pst" and select it.
Now it will be used for your post's in LCam and it will generate the G-code I posted.
Chip
« Reply #12 on: August 25, 2008, 08:37:49 PM »
Got it done, what a time saver. Thank you very much.
« Reply #13 on: August 25, 2008, 08:43:19 PM »
sorry to be such a bother Chip but now that I am looking at it isn't a circle one line of code. Under my entities it is showing as two entities and type is showing an arc.
« Reply #14 on: August 25, 2008, 08:48:05 PM »
I think I found what it was. I just needed to set the lead ins to zero. That seems to have fixed it.
Offline Chip
  •  2,055 2,055
« Reply #15 on: August 25, 2008, 08:49:03 PM »
Hi, David
Any Time, Chip
« Reply #16 on: August 25, 2008, 09:45:16 PM »
when I try to adjust where the cuts begin it changes the entity from cirlce to either arc or line.
« Reply #17 on: August 25, 2008, 09:45:53 PM »
sorry here is the lcam file
Offline Chip
  •  2,055 2,055
« Reply #18 on: August 25, 2008, 09:48:19 PM »
Hi, David
I don't see the problem hear with your LCAM file, Post the dxf.
Chip
« Reply #19 on: August 25, 2008, 10:23:39 PM »
here is what i see. Before I got the entity at the bottom to read circle and only have one entity instead of two.
