Hello Guest it is October 22, 2026, 04:11:36 PM
Author Topic: How do I remove this out of the gcode  (Read 55688 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: How do I remove this out of the gcode
« Reply #20 on: August 26, 2008, 12:41:52 AM »
Hi, David
The G-code that's produced are single circle's, Is this creating an Issue ?
Chip
« Reply #21 on: August 26, 2008, 05:56:39 PM »
Well today I have no issues guess less beer works uh.
« Reply #22 on: August 26, 2008, 06:09:03 PM »
Bite your tounge!  ;)
« Reply #23 on: August 26, 2008, 08:24:06 PM »
 ;D
Don't think that was aimed at you Budman. LOL
« Reply #24 on: August 26, 2008, 09:11:26 PM »
what I was noticing when I started the program fresh today no problem, but once on for a while I tried opening up a dxf and boom 2 arcs for a circle. I closed the program and reopened it and back to circle it went. Now that I know what to do no big deal but I was just wondering if I am changing anything unknowingly to cause this to happen.
« Reply #25 on: August 27, 2008, 01:18:30 AM »
Can you post a screenshot of what you see? sounds kind of like it might be an IJ mode issue but why I am not sure.
« Reply #26 on: August 27, 2008, 09:48:57 PM »
screen shot of what I saw is on the 2nd page bottom and I will post the screen shot when I freshly boot up lcam.
« Reply #27 on: August 27, 2008, 10:00:55 PM »
ok just got it to do it on a fresh dxf. You'll notice it made two arc entities to make the circle.
« Reply #28 on: August 27, 2008, 10:02:50 PM »
Closed lcam and opened the same dxf and back to cirlces with one entity.
« Last Edit: August 27, 2008, 10:06:28 PM by davy182 »
« Reply #29 on: August 27, 2008, 10:07:56 PM »
Just out of curiousity, try setting your connection tolerance to 0.0100  in the EXTENTS tab.
RC
« Last Edit: August 27, 2008, 10:13:11 PM by Overloaded »
