Hello Guest it is October 22, 2026, 03:35:43 PM
Author Topic: How do I remove this out of the gcode  (Read 55682 times)
« on: August 24, 2008, 09:27:12 PM »
How can I remove the N35  Z0.7200  and all the ones just like it. I have been doing it manually and that sucks on some of the larger codes I create.
Re: How do I remove this out of the gcode
« Reply #1 on: August 24, 2008, 09:33:47 PM »
Davy, how are you generating the code? Is this a safe z move?
« Reply #2 on: August 24, 2008, 09:54:59 PM »
through lazy cam, where whould a safe z move settings be located.
Davy
« Reply #3 on: August 24, 2008, 09:58:26 PM »
The z height of .72 is added in somehow. No matter the shape with a multiple depth cuts it adds it in, instead of just going to the next depth.
« Reply #4 on: August 25, 2008, 08:50:48 AM »
Davy,
One way to make editing a little easier is to open the file with Microsoft Word.
Then use EDIT>FIND>REPLACE Z******************x
                               REPLACE WITH (Z******************x)
                                check REPLACE ALL
« Reply #5 on: August 25, 2008, 08:54:32 AM »
Davy, post you Lazycam project and I'll try to see if I can eliminate them.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #6 on: August 25, 2008, 12:44:17 PM »
Hi, Dave
What are the values in the, Layer Tab, Cut Box,
Post your lcam or dxf file.
Chip
Offline Chip
  •  2,055 2,055
« Reply #7 on: August 25, 2008, 05:38:50 PM »
Hi, Davy
Try this post below, It has one Issue, It doesn't like final pass less than a Full "Pass Depth" in Tool setings, Sometimes, See Pic.
It needs to be in your C:\Mach3 Folder to set it in Lazyam.
Hope this Helps, Chip
« Reply #8 on: August 25, 2008, 07:05:04 PM »
Here is the lcam file that I am working with at the moment. I tried with depth starting at zero and going to negative and then starting at material height then going to zero with the same effects. I am going to try some of the others items mentioned here in a second.
David
Offline Chip
  •  2,055 2,055
« Reply #9 on: August 25, 2008, 07:39:28 PM »
Hi, David
Hears a post with even depth's per pass, Total depth .6 and per pass .2 look's good hear.
Chip
