Hello Guest it is November 23, 2026, 01:33:48 AM
Author Topic: Mach3 Loads files when e-stopped but not when in normal mode  (Read 14608 times)
« on: August 22, 2008, 01:12:24 PM »
Hello,
I've been fussing with Mach3 the last couple days, the problem i'm having is that when I first load mach3 up and I load any gcode file it will load great even the samples that come with the program. If I press the e-stop to bring the system to normal mode and try to load a gcode file I will get only like 1/4 of the program. If I exit mach and return and try again it will load the files fine untill you press e-stop then it will start doing it again.
Any ideas?
I'm runing Windows XP
256MB graphics card
1gb ram
Re: Mach3 Loads files when e-stopped but not when in normal mode
« Reply #1 on: August 22, 2008, 01:29:34 PM »
Never seen that before, could you please attach your xml and I will see if I can find anything.
« Reply #2 on: August 22, 2008, 01:43:24 PM »
Also it's worth mentioning that I also deleted the XML and recreated it just to be sure. The other strange thing is that if I load the file while the machine is estopped and then I bring it online and start cutting it will stop cutting the job about the same place that it truncates the file if you load it while in normal mode.
« Reply #3 on: August 22, 2008, 02:02:52 PM »
Is this a demo version and is it abut 500lines that it stops at?
