Mach Discussion => General Mach Discussion => Topic started by: jcdillin on August 22, 2008, 02:12:24 PM
Hello,
I've been fussing with Mach3 the last couple days, the problem i'm having is that when I first load mach3 up and I load any gcode file it will load great even the samples that come with the program. If I press the e-stop to bring the system to normal mode and try to load a gcode file I will get only like 1/4 of the program. If I exit mach and return and try again it will load the files fine untill you press e-stop then it will start doing it again.
Any ideas?
I'm runing Windows XP
256MB graphics card
1gb ram
Never seen that before, could you please attach your xml and I will see if I can find anything.
Also it's worth mentioning that I also deleted the XML and recreated it just to be sure. The other strange thing is that if I load the file while the machine is estopped and then I bring it online and start cutting it will stop cutting the job about the same place that it truncates the file if you load it while in normal mode.
Is this a demo version and is it abut 500lines that it stops at?
