Hello
Guest
it is
November 22, 2026, 02:34:53 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Reversing trajectory of .DXF conversion
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Reversing trajectory of .DXF conversion (Read 30285 times)
Keith
187
on:
June 07, 2006, 12:37:16 PM »
Hi,is there a simple way to reverse the direction of the cut that Mach3 chooses when it converts a .dxf to G-code(like for a clean up cut).Right now I go in and reverse the order by editing the G-code which is fine but a bit tedious.-Keith
Logged
Brian Barker
3,860
Re: Reversing trajectory of .DXF conversion
Reply #1 on:
June 07, 2006, 05:23:44 PM »
Is this in LCAM?
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Keith
187
Reply #2 on:
June 07, 2006, 06:42:12 PM »
Nope,plain ol' .dxf conversion in Mach3 file choice
Logged
Brian Barker
3,860
Reply #3 on:
June 08, 2006, 05:25:07 AM »
It can not be done in that importer
Lazy Cam is free in the development version of Mach3...
Logged
www.machsupport.com
Keith
187
Reply #4 on:
June 08, 2006, 09:16:49 AM »
Oh well. YEah I figured LCam did it but I've been wating to finish this long group of pieces before I finally get to LCam. Next week...next project.Thanks Brain
Logged
MJR
Reply #5 on:
June 08, 2006, 11:03:02 AM »
Hey guys:
A little confused about LCam. I have Mach3 (not yet registered). Is LCam part of it already or do I need to download it.
I also had the same question about the direction of cut being different from one DXF conversion to the next.
Logged
Keith
187
Reply #6 on:
June 08, 2006, 11:15:15 AM »
Yes LCam is in Mach3 in the last few releases. Depending on how you save your .dxf(uh...and sometimes not depending on how you save it)sometimes a line can be dropped or the like in which case you'll get different approachs to the cut. Make sure your tolerances are correct when generating the g-code from the .dxf(compared to how you drew it) and also which version and the other parameters you choose when saving your .dxf in your CAD program and take a good long look at the display and g-code to make sure all is well. Otherwise the basic importing of a .dxf in Mach3 I find quite valuable.-Keith
Logged
MJR
Reply #7 on:
June 08, 2006, 11:27:03 AM »
Thanks Keith.
I will keep this in mind, as I am new to Cad & Cam stuff.
I currently use TurboCad v7.
Later.
Logged
Brian Barker
3,860
Reply #8 on:
June 08, 2006, 11:55:37 AM »
I am here if you have any problems in LazyCam
Logged
www.machsupport.com
ger21
6,295
Reply #9 on:
June 10, 2006, 09:56:52 AM »
When coverting .dxf's, the direction the line is drawn usually determiines direction of cut (unless the converter is joining lines, then all bets are off). try to make sure all your lines are drawn in the correct direction. Redraw if necessary.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
