Hello Guest it is November 27, 2026, 08:54:33 AM
Author Topic: Reversing trajectory of .DXF conversion  (Read 30358 times)
Offline Keith
  •  187 187
« on: June 07, 2006, 12:37:16 PM »
Hi,is there a simple way to reverse the direction of the cut that Mach3 chooses when it converts a .dxf to G-code(like for a clean up cut).Right now I go in and reverse the order by editing the G-code which is fine but a bit tedious.-Keith
Re: Reversing trajectory of .DXF conversion
« Reply #1 on: June 07, 2006, 05:23:44 PM »
Is this in LCAM?
www.newfangledsolutions.com
www.machsupport.com
Offline Keith
  •  187 187
« Reply #2 on: June 07, 2006, 06:42:12 PM »
Nope,plain ol' .dxf conversion in Mach3 file choice
« Reply #3 on: June 08, 2006, 05:25:07 AM »
It can not be done in that importer :( Lazy Cam is free in the development version of Mach3...
www.machsupport.com
Offline Keith
  •  187 187
« Reply #4 on: June 08, 2006, 09:16:49 AM »
Oh well. YEah I figured LCam did it but I've been wating to finish this long group of pieces before I finally get to LCam. Next week...next project.Thanks Brain
MJR
« Reply #5 on: June 08, 2006, 11:03:02 AM »
Hey guys:
A little confused about LCam.  I have Mach3 (not yet registered).  Is LCam part of it already or do I need to download it.
I also had the same question about the direction of cut being different from one DXF conversion to the next.
Offline Keith
  •  187 187
« Reply #6 on: June 08, 2006, 11:15:15 AM »
Yes LCam is in Mach3 in the last few releases. Depending on how you save your .dxf(uh...and sometimes not depending on how you save it)sometimes a line can be dropped or the like in which case you'll get different approachs to the cut. Make sure your tolerances are correct when generating the g-code from the .dxf(compared to how you drew it) and also which version and the other parameters you choose when saving your .dxf in your CAD program and take a good long look at the display and g-code to make sure all is well. Otherwise the basic importing of a .dxf in Mach3 I find quite valuable.-Keith
MJR
« Reply #7 on: June 08, 2006, 11:27:03 AM »
Thanks Keith.
I will keep this in mind, as I am new to Cad & Cam stuff.
I currently use TurboCad v7.
Later.
« Reply #8 on: June 08, 2006, 11:55:37 AM »
I am here if you have any problems in LazyCam :)
www.machsupport.com
« Reply #9 on: June 10, 2006, 09:56:52 AM »
When coverting .dxf's, the direction the line is drawn usually determiines direction of cut (unless the converter is joining lines, then all bets are off). try to make sure all your lines are drawn in the correct direction. Redraw if necessary.
