Hello Guest it is September 14, 2026, 12:31:54 AM
Author Topic: cnc router work  (Read 13508 times)
cnc router work
« on: August 19, 2008, 01:28:24 PM »
I'm looking to have small carbon composite parts trimmed, 2 different designs they're about 9x10x1.5 cm overall and the material thickness is 1mm. It would be an initial run of 30-40 pairs.
http://i298.photobucket.com/albums/mm274/snocutt/assem01.jpg
http://i298.photobucket.com/albums/mm274/snocutt/assem02.jpg
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: cnc router work
« Reply #1 on: August 19, 2008, 05:41:26 PM »
You asked about this some time back, what has happened, are you still having problems?
Graham.
Re: cnc router work
« Reply #2 on: August 19, 2008, 11:27:24 PM »
it's mostly about time. I've been a bit busy with other things. I will at some point get a proper router setup, then I'll start having problems.
