Hello
Guest
it is
October 31, 2026, 12:35:08 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
cnc router work
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: cnc router work (Read 13720 times)
snocutt
7
cnc router work
on:
August 19, 2008, 01:28:24 PM »
I'm looking to have small carbon composite parts trimmed, 2 different designs they're about 9x10x1.5 cm overall and the material thickness is 1mm. It would be an initial run of 30-40 pairs.
http://i298.photobucket.com/albums/mm274/snocutt/assem01.jpg
http://i298.photobucket.com/albums/mm274/snocutt/assem02.jpg
Logged
Graham Waterworth
2,785
Yorkshire Dales, England
Re: cnc router work
Reply #1 on:
August 19, 2008, 05:41:26 PM »
You asked about this some time back, what has happened, are you still having problems?
Graham.
Logged
snocutt
7
Re: cnc router work
Reply #2 on:
August 19, 2008, 11:27:24 PM »
it's mostly about time. I've been a bit busy with other things. I will at some point get a proper router setup, then I'll start having problems.
Logged
Print
Pages:
1
Go Up
« previous
next »
