Hello
Guest
it is
November 04, 2026, 03:16:38 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
SmoothStepper USB
(Moderator:
Warp9TD
My Lathe with the SmoothStepper
« previous
next »
Print
Pages:
1
2
3
4
5
6
Go Down
Author
Topic: My Lathe with the SmoothStepper (Read 131420 times)
docltf
354
Re: My Lathe with the SmoothStepper
Reply #30 on:
August 26, 2008, 04:11:47 PM »
thanks Hood
that is a lot of good numbers, makes a person think about going shopping.
bill
Logged
Carnoustie, Scotland
Reply #31 on:
August 26, 2008, 04:16:26 PM »
The lathe itself cost me £300 ($600 approx) but there were no servo drives with it (my friend got them) Think I have probably spent in the region of £1000 ($2000) on the lathe including the original purchase. I have now just got a BIG servo motor and drive that I hope to put on the spindle so that will add another £500 but it will be worth it if it works
Logged
Reply #32 on:
August 26, 2008, 04:31:07 PM »
This is the motor,
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=250276403349&ssPageName=STRK:MEWN:IT&ih=015
it is 12.5Kw, 83Nm (735 lbs in ) continuous torque 152.5Nm (1350 Lbs in) peak.
Last Edit: August 26, 2008, 04:33:21 PM by Hood
Logged
Reply #33 on:
August 28, 2008, 07:02:22 AM »
Peter
Have attached a file for a similar stub shaft to the one I did earlier except just quite a bit smaller. I have made it with a DOC of 1mm for the roughing which should be fine for your lathe. The speeds and feeds should also be fine for you if you are using carbide, I have noted in the code the tools that I used. I ran the code on the lathe here with 38mm dia EN24 and have taken a pic with the phone but will have to wait until I get home to download. It probably wont be worth seeing as the phone camera is not that great
Oh and the thread is M10
Logged
Reply #34 on:
August 28, 2008, 01:13:42 PM »
Here is a blurry pic taken with the phone but at least it shows the code works.
Logged
budman68
2,352
Reply #35 on:
August 28, 2008, 02:26:34 PM »
Hood, may I ask what version of Mach 3 Turn are you running?
Logged
Dave->
Reply #36 on:
August 28, 2008, 02:30:49 PM »
Yes you may
Logged
Reply #37 on:
August 28, 2008, 02:32:50 PM »
Sorry couldnt resist, at the moment I am using 3.042.005, I would however advise against using it unless you feel like being a guinea pig, it has a lot of changes in the way it works and there may well still be some undesireable bugs.
Logged
budman68
2,352
Reply #38 on:
August 28, 2008, 03:26:21 PM »
Funny stuff there, chief -
What would you recommend being the most stable yet up to date version of Mach 3 Turn?
Logged
Dave->
Reply #39 on:
August 28, 2008, 04:01:25 PM »
I dont know really, dont think there have been any Turn specific changes since way back (1.74 I think) so I suppose the lockdown will be fine. The latest ones once finished will make a big difference in the way VB works within Mach so it will be an advantage to use them but only after all the bugs have been ironed out.
Logged
Print
Pages:
1
2
3
4
5
6
Go Up
« previous
next »
