Hello Guest it is November 04, 2026, 03:16:54 PM
Author Topic: My Lathe with the SmoothStepper  (Read 131421 times)
Re: My Lathe with the SmoothStepper
« Reply #20 on: August 19, 2008, 12:49:43 PM »
;D
« Reply #21 on: August 19, 2008, 08:58:37 PM »
Peter, I could probably mount that in the turret ;D
Ask John Prentice, I am sure he would have some suitable code.
 What kind of depths do you reckon you could take off in one pass, maybe the code I have for the pullstud in the video would suit, it is just taking light cuts due to the distance out of the spindle, I think its only taking 1mm DOC for the most part.
Hood,
I'll email John and see if he has anything appropriate. Basically I'm after something about 4" in length with a taper and a thread that is not too fine. This the stub axle.
As to depth of cuts, all I can say is that it is a 7x14. :-)
Cheers,
Peter.
Homann Designs
http://www.homanndesigns.com
« Reply #22 on: August 20, 2008, 12:53:19 AM »
Peter let me know the dia and  I will adapt that file to suit for you.
« Reply #23 on: August 21, 2008, 05:09:35 PM »
Hi Hood,
1.5" diameter should be fine.
Cheers,
Peter.
Homann Designs
« Reply #24 on: August 21, 2008, 05:29:14 PM »
Peter should also have asked what feeds and speeds you have.
« Reply #25 on: August 24, 2008, 06:38:02 PM »
Hi Hood,
Spindle speed max is 2800
Max rapid is 7000mm/min
Cheers,
Peter.
Homann Designs
« Reply #26 on: August 26, 2008, 01:08:43 PM »
Peter
 Will be Thursday before I can do this and test it out on the lathe, I am working away from the workshop at the moment.
Offline docltf
  •  354 354
« Reply #27 on: August 26, 2008, 02:06:43 PM »
Hi ,Hood
what are the capacities of your lathe. you know the usual stuff,swing ,spindle bore ,bar feeder,etc,etc.
bill
« Reply #28 on: August 26, 2008, 02:36:06 PM »
Bill
 Max swing over bed is 520mm (19.69" approx)
 Max swing over saddle is 290mm (11.4" approx)
 Max distance between centres is 1000mm (39.4" approx)
 Spindle bore is 72mm (2.84" approx)
 Max weight in chuck is 280Kg (616lbs approx)
 Max Weight in Chuck and Tailstock is 500Kg (1100lbs approx)
 Tailstock stroke is 180mm (7" approx)
Tailstock barrel 90mm Dia (3.54" approx)
Tailstock taper Morse taper 5.
Weight without ancilliaries is approx 2750Kg (6050lbs)
Length 3500mm (137.8" approx)
width 2450mm (96.45"approx)
height 2075mm (81.69" approx)
« Reply #29 on: August 26, 2008, 02:39:50 PM »
Oh and as far as Bar feed, dont have one, the lathe originally had a closed centre hydraulic chuck which was no use for the work I do so I replaced it with a 250mm Dia 6 jaw manual . Always on the lookout for a 250mm- 300mm  hydraulic through hole chuck at the right price but not got one yet ;)
« Last Edit: August 26, 2008, 02:41:37 PM by Hood »
