Hello Guest it is November 19, 2026, 02:42:18 AM
Author Topic: cnc plasma table...  (Read 74770 times)
Re: cnc plasma table...
« Reply #20 on: August 16, 2008, 12:31:16 PM »
I will have another look at your xml in 1/2 hour, just got to get back to the workshop.
« Reply #21 on: August 16, 2008, 01:49:01 PM »
Ok your xml here seems to be working fine, I have changed the Output Port and pin to the correct ones and attached it. Download then rename to whatever the name it originally was and paste it to your Mach3 folder and see if you can get things goi9ng.
« Reply #22 on: August 16, 2008, 04:16:56 PM »
Hood thanks for you support & I hope you don't give up on me!
Always something else, now is requesting for external E-Stop???
uuccimi - novice
« Reply #23 on: August 16, 2008, 04:45:59 PM »
sorry been testing stuff here fro Brian and Greg, now I need to go home. That message is either your e-stop is set wrong or your limits are set wrong, both in ports and pins , inputs. Have a look on the diagnostics page and see if either the limits or e-stop LED are lit.
OK off home now getting late here but will log on when I get home.
« Reply #24 on: August 16, 2008, 07:04:45 PM »
Diagnostics: Yes, emergency are blinking ! but don't how to correct this
...Ports & Pins ---> Input Signals---> EStop Enabled, Port 1, Pin 10
But Fiscally I don't have a EStop botton in the machine
Wait a second, If I open mach3 for the first time and closed and open again and closed, the computer died, so I have to hold on/off botton to be able to shut down and turn on again
« Last Edit: August 16, 2008, 07:10:03 PM by uuccimi »
uuccimi - novice
« Reply #25 on: August 16, 2008, 08:59:10 PM »
Change its active state from active low to active High or visa-versa and see if that fixes you up.
« Reply #26 on: August 16, 2008, 09:19:22 PM »
That don't do any thing good, to prevent the PC from died!
uuccimi - novice
« Reply #27 on: August 17, 2008, 04:20:09 AM »
You are not using the xml I posted, the one I posted is an exact copy of the one you originally posted withthe exception of OutPut 1 being set correctly to port 1 instead of port 17.  In the xml I posted  the E-Stop is set to port 0 pin 0 .
Is this definitely the correct xml that you posted? Have a look at the shortcut you use to start Mach from, what is it called? If it is Mach3Mill or Mach3Plasma then right click on the icon and choose properties and look at the target, note the name of the target file and that is the xml you want to attach to the forum.
 Do you have limits on your plasma?
Do you have an physical E-Stop button on your plasma?
Is it a home made machine or just one you have bought or are converting? If its the latter two then please provide a link to the manufacturers website so that we can get an idea of how it is set up. If you can attach pics of your machine if it is home made then that may also help us to provide info.
« Reply #28 on: August 17, 2008, 09:49:31 AM »
Yes I did use the xml you posted!
Yes is a Mach3Mill XML!
NO I don't have a limits switchs yet!
I don't have a physical E-Stop yet!
YES is a home made machine
But the funny part is that the PC died with the machine unhook from the parallel port
xml file again... here
« Last Edit: August 17, 2008, 09:52:01 AM by uuccimi »
uuccimi - novice
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #29 on: August 17, 2008, 10:47:13 AM »
Hi, Uuccimi
Just looked at your xml, There are several issues.
Give me a call on Skype if you like, Maybe we can sort this out.
Chipl
