Hello Guest it is November 19, 2026, 02:42:19 AM
Author Topic: cnc plasma table...  (Read 74770 times)
Re: cnc plasma table...
« Reply #10 on: August 16, 2008, 10:03:56 AM »
Use the full reply page and then use the additional options button. You can then browse your hard drive and choose it.
I used modify and find the way to attach the file as you can see above!
uuccimi - novice
« Reply #11 on: August 16, 2008, 10:08:26 AM »
Ok in that profile you have Output 1 set for port17 pin 0, I would imagine it should be set to Port 1 Pin 17
« Reply #12 on: August 16, 2008, 10:35:53 AM »
Sorry my bad
Now the Mach3 doesn't want to work.
I hit the arrow in the keyboard as usually but the number in the DRO doesn't move!
You think that I should unistall and installed again?
uuccimi - novice
« Reply #13 on: August 16, 2008, 10:37:36 AM »
It may be that you have the Jog control button off, check there is green surrounding it.
« Reply #14 on: August 16, 2008, 10:52:42 AM »
When I first load Mach3 al the 4 DRO are red but I click Ref All Home and all 4 went to green
Also click Jog Follow to green
hit the arrows in the keyboard and nothing happen
Let me picture what green botton are:
The 4 DRO X, Y, Z, A
M1 Optional Stop
CV Mode
Reset
That's it
uuccimi - novice
« Reply #15 on: August 16, 2008, 11:10:33 AM »
OK on the main screen bottom middle area you should see Jog On/off button
« Reply #16 on: August 16, 2008, 11:18:49 AM »
Yes, I did click on it! (green on or green off)
Click the keyboard arrows... and nothing happend
uuccimi - novice
« Reply #17 on: August 16, 2008, 11:27:06 AM »
Hi Hood,
Can we chat over Skype - if you have the kind and time?
uuccimi - novice
« Reply #18 on: August 16, 2008, 11:41:28 AM »
sorry dont have skype phone here :(
« Reply #19 on: August 16, 2008, 11:44:45 AM »
Skype are chat like "hotmail messenger"
or chat with hotmail
Any way do you think, that should unistalled?
« Last Edit: August 16, 2008, 11:49:49 AM by uuccimi »
uuccimi - novice
