Hello Guest it is November 19, 2026, 02:42:18 AM
Author Topic: cnc plasma table...  (Read 74770 times)
Re: cnc plasma table...
« Reply #30 on: August 17, 2008, 12:18:23 PM »
Afraid that is a totally different xml from the last one you posted, hopefully Chip can get things sorted via a skype, if not please come back again and list what hardware you have, how it is connected (Pin and port numbers) and we should be able to get things going.
« Last Edit: August 17, 2008, 12:22:00 PM by Hood »
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #31 on: August 17, 2008, 01:14:15 PM »
Hi, Hood
Spent some time on the phone, Think we have things "sorta" sorted out, First few step's on the ladder are pretty far apart, As you now.
Should be seeing more questions soon.
Thanks, Chip
« Reply #32 on: August 17, 2008, 01:22:14 PM »
excellent Chip :)
« Reply #33 on: August 17, 2008, 07:37:54 PM »
I wnat to thanks Chip again for the great lesson that help me a lot!
Right now I experienced with 2.63 special with the plasma 2.0 and just notices that 2.63 are not allowed to import HPLG/BMP/JPG also DXF!!
The other think is when a import a g-code into Mach plasma y I click Edit G-Code button don't open the notepad with the code!
But so far so good, don't know what else I'll find in the path of learning Mach
Thanks again!
« Last Edit: August 17, 2008, 07:54:25 PM by uuccimi »
uuccimi - novice
« Reply #34 on: August 17, 2008, 07:39:53 PM »
The reason are because I did re-installed WindowsXP again and also Mach3...!!!
uuccimi - novice
« Reply #35 on: August 18, 2008, 01:06:59 AM »
Later versions use LazyCAM for the importing and converting.
Config, General Config and then you will see the pathe of the editor, should be \Windows\Notepad.exe   but you can browse to any editor you like.
