Hello
Guest
it is
November 23, 2026, 09:39:38 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Reversing Servo Direction
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Reversing Servo Direction (Read 14585 times)
BigD
7
on:
June 04, 2006, 03:07:03 PM »
Could someone explain to me how to reverse the direction of the servo motor in Mach3. The X and Y are moving the wrong direction
Brian Barker
3,860
Re: Reversing Servo Direction
Reply #1 on:
June 04, 2006, 03:31:11 PM »
Under homing and limits there is a place to reverse the direction. As soon as you change to exit Mach3 (this will back up the XML file) then you can reopen it and should be good to go
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
