Hello Guest it is November 23, 2026, 09:39:46 PM
Author Topic: Reversing Servo Direction  (Read 14586 times)
« on: June 04, 2006, 03:07:03 PM »
Could someone explain to me how to reverse the direction of the servo motor in Mach3.  The X and Y are moving the wrong direction
Re: Reversing Servo Direction
« Reply #1 on: June 04, 2006, 03:31:11 PM »
Under homing and limits there is a place to reverse the direction. As soon as you change to exit Mach3 (this will back up the XML file) then you can reopen it and should be good to go :)
www.newfangledsolutions.com
www.machsupport.com
