Hello Guest it is August 23, 2026, 05:37:41 PM
Author Topic: ROUTER STOPPING DURING PROGRAM RUN  (Read 29593 times)
« on: August 02, 2008, 10:57:35 AM »
RUNNIG THE ATTACHED PROGRAM USING A 1/16" CARBIDE , THE ROUTER WILL STOP COMPLETELY.  PRIOR TO STOPPING I NOTICE THE HESITATION AT THE END OR BEGINNING OF THE ARCS.  IT GENERALLY HAPPENS ABOUT THE THIRD OR FORTH PASS.
I NEED SO DIRECTION.............PLEASE
INIVATOR
Re: ROUTER STOPPING DURING PROGRAM RUN
« Reply #1 on: August 02, 2008, 11:37:29 AM »
Seems to run fine in simulation here, mill is busy at the moment so cant try it but will do soon.
 Are there any error messages in the status window?
 Does Mach stop or is it just your router?
Please attach your xml and I will have a look.
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
« Reply #2 on: August 02, 2008, 11:41:20 AM »
I ran your program on this computer (not attached to the machine) and it functioned perfectly, following the tool path display.
It seems to be the same cuttings at three (maybe four) different depths in five different locations (inner square, inner butterfly, inner butterfly, inner square, then outer  what looks like a doll on its side. Which pass are you saying it generally fails on.
I was going to say Mach download only does 500 lines, but that cannot be the reason, because you are well short of that. Is there anything mechanical causing your router to stop - are you going too deep, are you hitting any stops. When you say the router just stops, what does it do -
gradually slow down.
bounce about and stop.
just die. -
I cant see any reason without a bit more information.
« Reply #3 on: August 02, 2008, 11:48:21 AM »
NO THE MACHINE STOPS.
INIVATOR
« Reply #4 on: August 02, 2008, 11:52:24 AM »
What do you mean by the machine stops? are you meaning its only the router that is stopping and Mach is continueing to run?
 If so then its a hardware issue you have, so check all connections properly.
« Reply #5 on: August 02, 2008, 11:52:43 AM »
I ALSO NOTICE THAT THE MACHINES STOPS FOR A MILISECOND AND THE START OF THE ARCS, THE RUNS FOR A SHORT TIME, THEN COMPLETELY STOPS.
THE ROUTER CONTINUES TO RUN.
INIVATOR
« Last Edit: August 02, 2008, 11:54:27 AM by inivator »
« Reply #6 on: August 02, 2008, 12:06:35 PM »
NO JIM, THE MACHINE JUST QUITS OR DIES, AND THE RESET BUTTON IS ACTIVATED, BUT IT HITS NO LIMITS SWITCHES...  I CAN RESET, AND REHOME, AND START THE MACHINE AGAIN, IT WILL EVENTUALLY STOP, NOT ALWAYS IN THE SAME PLACE OF SAME DEPTH..
INIVATOR
« Reply #7 on: August 02, 2008, 12:18:48 PM »
You have noise on the limits, do you hasve them connected with shielded wire? Do you have the shielding connected to ground at the control end only?
 If yes to above then try increasing the debounce to 2000 and see if it cures it, if it does then keep dropping the debounce until it happens again and then increase slightly.
« Reply #8 on: August 02, 2008, 12:21:31 PM »
NOT USING SHEILDED WIRE.  WILL INCREASE THE DEBOUNCE, AND SEE IT THAT HELPS.
THANKS FOR THE INFO AND HELP
INIVATOR
« Reply #9 on: August 02, 2008, 12:27:13 PM »
Best to get your limits wired with shielded wire but debounce will let you know for sure its noise.
