Hello Guest it is October 14, 2026, 05:25:21 AM
Author Topic: ROUTER STOPPING DURING PROGRAM RUN  (Read 30032 times)
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: ROUTER STOPPING DURING PROGRAM RUN
« Reply #10 on: August 02, 2008, 12:28:05 PM »
I agree- noise on the limit switch wires, or a faulty switch is the most probable cause -
If you are sure that you are nowhere near the limits with the program go to Config/Ports and Pins/ Inputs and cancel all the limit switch enables (you can leave the pin settings and keep the homes) and try a test run on that. If it works without stopping, then as Hood says, you have interference on the limit switch wiring.
« Reply #11 on: August 02, 2008, 12:30:24 PM »
CAN SMALL SHEILDED WIRE BE PURCHASED AT PLACES LIKE RADIO SHACK?  HOOD, MAYBE YOU DON'T HAVE SUCH PLACES IN YOU COUNTRY..............
INIVATOR
« Reply #12 on: August 02, 2008, 12:38:54 PM »
We have similar kinds of places but eBay is often a good place to get it, you can often find a whole coil for less than the price of a couple of feet from a store. Make sure the core is not solid, get multistrand or after a while the vibration of the machine will crack the core and you will have nightmares.
« Reply #13 on: August 02, 2008, 12:43:25 PM »
THANKS GUYS FOR THE HELP.  I WILL REPLACE THE WIRE WITH SHEILDED WIRE, AND HOPE THAT THAT SOLVES ALL MY PROBLEMS.
BOTH OF YOU GUYS, HOOD AND JIM, HAVE BEEN A GREAT HELP......
WHAT EVER YOU GET FOR PAY FOR SUPPORT, IT IS NOT ENOUGH......
I HOPE THAT THANKS FOR THE HELP WILL HELP..
INIVATOR FROM TEXAS......USA
Offline Kristin D
  •  203 203
  • Take that you LazyCam, next stop the glue factory!
« Reply #14 on: August 02, 2008, 02:01:11 PM »
I got my shielded wire from allelectronics.com 22GA 5 conductor with a ground and foil shield was pretty cheap/foot. stock # 5CS22, I bought 100' but you can buy 1' to 500'
Kristin
