Hello
Guest
it is
October 21, 2026, 01:16:33 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
1000 CPR encoder
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: 1000 CPR encoder (Read 20706 times)
cncnut
5
1000 CPR encoder
on:
December 09, 2005, 07:40:32 PM »
I have a 1000 cpr encoder on my X servodrive running at 2700 rpm. I need to know if I move the encoder to a shaft on the same X drive that only runs 245 rpm, will it work or will i need a different cpr encoder.
cncnut
Brian Barker
3,860
Re: 1000 CPR encoder
Reply #1 on:
December 10, 2005, 06:00:01 AM »
There are machines that do this. It is not the best way but if you have a zero backlash belt drive or coupling it should work. That said the best way is to change the encoder.
Hope that helps
Brian
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
