Hello Guest it is October 21, 2026, 01:09:23 PM
Author Topic: NOISE PROBLEMS  (Read 40214 times)
Re: NOISE PROBLEMS
« Reply #10 on: July 06, 2008, 07:31:42 AM »
I hope this is right..................
inivator
Re: NOISE PROBLEMS
« Reply #11 on: July 06, 2008, 07:38:36 AM »
Have a look on the diagnostics page, do you see the limits lit?
Re: NOISE PROBLEMS
« Reply #12 on: July 06, 2008, 07:40:07 AM »
Oh another thing, you have Output 1 enabled but no pin set for it, either disable it or set the correct pin.
Re: NOISE PROBLEMS
« Reply #13 on: July 06, 2008, 07:53:57 AM »
There are no limits lit on that page.
Inivator
Re: NOISE PROBLEMS
« Reply #14 on: July 06, 2008, 08:04:18 AM »
no limits lit on that page :-\ :-\
Re: NOISE PROBLEMS
« Reply #15 on: July 06, 2008, 08:10:24 AM »
when you press a limit do they light? If not then disconnect your parallel port cable and touch pin 12 to ground on the port itself with a piece of wire. your limits should light on the diagnostice page.
Re: NOISE PROBLEMS
« Reply #16 on: July 06, 2008, 08:19:56 AM »
Is that done with the paralell port cable still un-attached?
Re: NOISE PROBLEMS
« Reply #17 on: July 06, 2008, 08:27:51 AM »
Yes, the pin on the parallel port on the back of the PC. Disconnect the cable so you can get to the pin and ground it as you watch the diag. page. Should see the input go active.
Re: NOISE PROBLEMS
« Reply #18 on: July 06, 2008, 08:33:42 AM »
Disconnect the p.p. cable from the computer, and ground the pin 12 to ground in the db-25 connector.  Is that right.
Re: NOISE PROBLEMS
« Reply #19 on: July 06, 2008, 08:35:54 AM »
Pin 12 on the computers parallel port to the metal housing on that port.
