Hello Guest it is October 21, 2026, 10:05:33 AM
Author Topic: NOISE PROBLEMS  (Read 40207 times)
Re: NOISE PROBLEMS
« Reply #20 on: July 06, 2008, 08:41:28 AM »
Ok, but first I have to look up the pin layout on the connector.  I don't know just where pin 12 is.
Inivator
Re: NOISE PROBLEMS
« Reply #21 on: July 06, 2008, 08:47:03 AM »
http://www.lammertbies.nl/comm/cable/parallel.html#prnt
They should be numbered. Hard to see, but should be.
Re: NOISE PROBLEMS
« Reply #22 on: July 06, 2008, 08:59:04 AM »
When I ground the pin 12, the light come on........... :D :D
Re: NOISE PROBLEMS
« Reply #23 on: July 06, 2008, 09:22:06 AM »
That means the problem is in your wiring or breakout. Next connect the cable back to the port but disconnect from the breakout and check at the cable by grounding its pin to ground. If that lights up the LEDs then check your breakout with a voltmeter when you are operating the limits.
