Hello Guest it is November 01, 2026, 11:01:43 AM
Author Topic: Circles from Lcam to Mach 3  (Read 15883 times)
« on: June 18, 2008, 12:19:24 AM »
I can export gcode on a square or rectangle and have it work with lcam but when I import a dxf with circles in it the gcode goes all weird in Mach 3. Help someone
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Circles from Lcam to Mach 3
« Reply #1 on: June 18, 2008, 01:28:25 AM »
Hi, kevoler
Use the REPLY button hear and attach your example DXF file
Thanks, Chip
« Reply #2 on: June 18, 2008, 09:52:19 AM »
Here is the dxf file and the tap file which Lcam created.
Offline Chip
  •  2,055 2,055
« Reply #3 on: June 18, 2008, 12:34:32 PM »
Hi, kevoler
I loaded your dxf and posted it, It looks fine hear, See below.
What ver of Mach & LazyCam are you using, Look under Help, "About" in both.
Using Mach R3.041 & LC 3.00.2 hear.
Let Us Now, Chip
« Reply #4 on: June 18, 2008, 03:30:19 PM »
Hi Chip,
I downloaded your tap file and it works great. Here is what mine looks like. I will keep at it.
« Reply #5 on: June 18, 2008, 09:51:06 PM »
I downloaded and installed the newer versions and all worked great. Thank you for your time
Offline Chip
  •  2,055 2,055
« Reply #6 on: June 18, 2008, 09:56:42 PM »
Hi, kevoler
I think it might be the "Default Plasma Post",  Try the "Default Mill" post and see if thats it.
Thanks, Chip
« Last Edit: June 20, 2008, 12:52:27 AM by Chip »
