Hello
Guest
it is
November 01, 2026, 11:48:31 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
G-Code, CAD, and CAM
LazyCam (Beta)
Circles from Lcam to Mach 3
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Circles from Lcam to Mach 3 (Read 15886 times)
kevoler
7
on:
June 18, 2008, 12:19:24 AM »
I can export gcode on a square or rectangle and have it work with lcam but when I import a dxf with circles in it the gcode goes all weird in Mach 3. Help someone
Chip
2,055
Gainesville Florida USA
Re: Circles from Lcam to Mach 3
Reply #1 on:
June 18, 2008, 01:28:25 AM »
Hi, kevoler
Use the REPLY button hear and attach your example DXF file
Thanks, Chip
kevoler
7
Reply #2 on:
June 18, 2008, 09:52:19 AM »
Here is the dxf file and the tap file which Lcam created.
Chip
2,055
Reply #3 on:
June 18, 2008, 12:34:32 PM »
Hi, kevoler
I loaded your dxf and posted it, It looks fine hear, See below.
What ver of Mach & LazyCam are you using, Look under Help, "About" in both.
Using Mach R3.041 & LC 3.00.2 hear.
Let Us Now, Chip
kevoler
7
Reply #4 on:
June 18, 2008, 03:30:19 PM »
Hi Chip,
I downloaded your tap file and it works great. Here is what mine looks like. I will keep at it.
kevoler
7
Reply #5 on:
June 18, 2008, 09:51:06 PM »
I downloaded and installed the newer versions and all worked great. Thank you for your time
Chip
2,055
Reply #6 on:
June 18, 2008, 09:56:42 PM »
Hi, kevoler
I think it might be the "Default Plasma Post", Try the "Default Mill" post and see if thats it.
Thanks, Chip
Last Edit: June 20, 2008, 12:52:27 AM by Chip
Print
Pages:
1
Go Up
« previous
next »
