Hello Guest it is October 22, 2026, 08:40:34 PM
Author Topic: Unable to JOG BACK on Mach3 after limit-switch-tripping  (Read 20393 times)
« on: May 05, 2008, 07:56:51 PM »
This is a Question for a moderator (programmers of MACH)
I found this question on the Spanish forum.  I thought it was a good technical question and maybe one that deserves the programmers looking into for modification:
Translated from Spanish:
With mach2 if I had a runoff and activated the Reset, (limit switch) then what I would do is to deactivate, with the mouse, the button of reset and with the cursors, jogged back to operating space.
Now with mach3 I cannot do that, if I trip the limit switch, it does not let me deactivate it with the mouse, reason why must turn off the milling machine and turn by hand the small spindle.
Does anyone know How the RESET status can be deactivated?? (to anable jogging back)
a greeting and thousand thanks --cchhaa
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Unable to JOG BACK on Mach3 after limit-switch-tripping
« Reply #1 on: May 05, 2008, 09:13:15 PM »
Hi, Cchhaa
Look at this Post,  http://www.machsupport.com/forum/index.php/topic,6695.0.html
Hope this Helps, Chip
« Reply #2 on: May 05, 2008, 10:22:13 PM »
Thanks Chip!!
--CNC4fun
(not Cchhaa.  that was part of the translation)
I did post your answer on the spanish forum and gave you credit.
Cheers.
« Last Edit: May 05, 2008, 10:25:49 PM by CNC4fun »
Offline Chip
  •  2,055 2,055
« Reply #3 on: May 05, 2008, 10:32:31 PM »
Hi, CNC4fun
Glad to help.
Thanks, Chip
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
« Reply #4 on: May 06, 2008, 12:33:35 PM »
Better still - I f you have the "Auto Limit Override" selected, this will allow you to reset the Limit Switch and back off the switch automatically. It then resets it to the limit again.
