Hello Guest it is November 13, 2026, 03:48:24 PM
Author Topic: cnc machine running when start windows 2000  (Read 42691 times)
« on: March 27, 2008, 05:28:30 PM »
hello when i start up my computer running windows 2000 my cnc mill start running
some one have a idee how that can be running onder dos with pcnc it,`ok
Re: cnc machine running when start windows 2000
« Reply #1 on: March 27, 2008, 05:38:26 PM »
What do you mean start running? Just motors twitching or motors actually taking off and moving all the time?
« Reply #2 on: March 27, 2008, 05:41:55 PM »
Yes the motors actually taking off and moving all the time  ???
« Reply #3 on: March 27, 2008, 05:49:04 PM »
Sounds like you must have something interfering with the parallel port. Run the DriverTest and see what the line looks like in that.
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #4 on: March 28, 2008, 09:17:08 AM »
Are you using a charge pump? If not do a  search for 'charge pump', it it designed to keep your motors off until Mach starts...
Happy machining , Jeff Birt
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #5 on: March 28, 2008, 01:00:55 PM »
Hi jd1uth
seems your saying before you even start Mach right?
Maybe you have a printer driver in there as well as the pulse engine and a document in W2Ks print queue? - just a (wild) thought...
Whatever, best not to start windoze with the rig switched on. Whilst booting a PC and loading W2K, the parallel port is chucking out all sorts of garbage. Turn your machine off until it's is up at least - preferably wait until Mach is up and running.
« Reply #6 on: March 29, 2008, 03:15:40 PM »
driver change and it`s ok now but the movements are not yet ok
« Reply #7 on: March 30, 2008, 04:43:29 PM »
It`s not running  ???
I`m use pc-nc under DOS and it`s works ok now i whane use mach3 and notting is working
do i have to change the wirering ??????
steps =
Japan Servo KH56QM2-951:
2-Phasen Schrittmotor
1,323 Nm Haltemoment (unipolar)
1,8° Schrittwinkel (200 Vollschritte/Umdrehung)
4 Anschlüsse, bipolar ansteuerbar
Maße: 56x56x76mm, Wellen-Durchmesser: 6,35mm (1/4")
Elektrische Daten: 2,0 A, 4,0 V, 2,0 Ohm, 7,35 mH
http://www.nc-step.de/motor.html
stepdriver=3-Kanal Schrittmotorkarte 'Step-3D'
http://www.nc-step.de/step3d.html
wirering at the bottum of page
mach3 setting
                       enable  step-pin          Dir pin          Dir low              step low             step port              dir port
x axis                enable         2                3        1                       1
Y axis                enable         5               4        1                       1
z axis                 enable         7               6        1                       1
so far and notting is working  normal ??? z axis is responding on keyboard then its running up by pressing down it stops
By pressing x axis z an x are moving by hidding a other key it stops
help please
« Reply #8 on: March 30, 2008, 04:54:54 PM »
Hallo,
no need to change wiring if it works under Dos it should work under Mach3,
It has someting to do with your setup,First you need to get rid of the dos drivers, rename autoexec.bat and config.sys so the drivers are not loaded. then try again
Thanks Friedrich
« Reply #9 on: March 31, 2008, 02:51:28 PM »
No driver loaded in config.sys or autexec.bat and under windows 2000 no printer instald
configuration according to Mr. Wincklers page:
http://www.cnc-winckler.de/Mach3/Konfiguration/konfiguration.html
