Hello Guest it is September 18, 2026, 06:59:03 AM
Author Topic: Mach IV Tool Offset  (Read 18005 times)
Mach IV Tool Offset
« on: May 02, 2006, 06:24:59 PM »
I have my GREX/Mach IV system up and running.  Great stuff!    It appears that the start and end points of a line are wrong when using part offset and/or scaling.  Has anyone else seen this?
Re: Mach IV Tool Offset
« Reply #1 on: May 02, 2006, 07:08:52 PM »
That may not be turned on the the software... I will forward that off to Art.
www.newfangledsolutions.com
www.machsupport.com
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
« Reply #2 on: May 02, 2006, 07:58:42 PM »
Hi :
 I havent tested scaleing, but part offsets should work.. Ill check it out though..
 Do ytou mean like G55 G56 , or just zeroing ??
Art
« Reply #3 on: May 09, 2006, 05:26:29 PM »
I was referinng to G41 and G42.  Due to my failure to read the tutorial, I was not aware that tool offsets are such a problem.  I was using the Mach 3 HPGL import.  I have since learned how to make Lazycam work.  It is actually quite easy once you find the layer control button.  The leadins make it all work much better.  I will post my remaing concerns in the general section. Thanks
