Hello
Guest
it is
November 15, 2026, 10:52:08 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Jogging x1 x10 x100 instead of velocity
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Jogging x1 x10 x100 instead of velocity (Read 19500 times)
beezerlm
57
on:
February 11, 2008, 09:29:13 PM »
Hello,
Trying to Jog with cnc4pc mpg-2 hooked up to lpt2. It moves all axis but I cannot adjust the increment it moves per click of the mpg. x1 x10 x100 are all the same amount no matter what I do. Seems like I am stuck in velocity mode or something.
Any Ideas?
Logged
arturod
172
Re: Jogging x1 x10 x100 instead of velocity
Reply #1 on:
February 16, 2008, 03:04:44 PM »
Jog increment does not work with all jog modes. Make sure you have configured those job modes under general configuration screen.
Arturo Duncan
http://cnc4pc.com
Logged
beezerlm
57
Reply #2 on:
February 16, 2008, 03:13:42 PM »
Arturo,
I have configured the x1 x10 and x100 as shown is lpt2 Mpg-2 setup manual under general configuration screen.
X1 is .0001
X10 is .0010
X100 is .0100
Logged
arturod
172
Reply #3 on:
February 16, 2008, 03:16:58 PM »
Try using different jog modes. Go the the diagnostics screen and confirm that the inputs are changing as you turn the selector.
Arturo Duncan
http://cnc4pc.com
Logged
beezerlm
57
Reply #4 on:
February 16, 2008, 03:21:21 PM »
All jog modes give me the same result. I look at the function of the brain and I can see it switching from x1 to x10 to x100. It does not jog any different though.
Logged
arturod
172
Reply #5 on:
February 16, 2008, 03:26:29 PM »
Do you see in the MPG window? when you press tab? do you see it changing?
Arturo Duncan
http://cnc4pc.com
Logged
beezerlm
57
Reply #6 on:
February 16, 2008, 03:28:30 PM »
I see mpg window, I flip through the different jog modes, but x1 x10 and x100 do not change anything?
Logged
beezerlm
57
Reply #7 on:
February 17, 2008, 06:49:15 PM »
success!
I shut my system down, double checked all connections, booted back up and single step/multistep worked with the mpg. Not quite sure what the problem was. I was stuck in velocity mode for some reason. Thanks for the Help!
Last Edit: February 17, 2008, 06:51:21 PM by beezerlm
Logged
arturod
172
Reply #8 on:
February 18, 2008, 04:33:51 AM »
Glad to hear all is well.
Arturo Duncan
http://cnc4pc.com
Logged
Print
Pages:
1
Go Up
« previous
next »
