Hello Guest it is November 22, 2026, 07:07:11 AM
Author Topic: Actual cutting path is not cutting over gcode path  (Read 11820 times)
« on: February 11, 2008, 03:43:12 PM »
I have a problem the Code path and the actual cutting path are off by 12 or more inches this is for a water jet and always uses relative coordinates.
Wayne
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Actual cutting path is not cutting over gcode path
« Reply #1 on: February 11, 2008, 04:21:22 PM »
Hi, Wayne
Sounds like you have a work offset issue, Look on the Offsets page, Click the Machine Coord's Button, Do the DRO's change values ?
If thy do, change to your Program Run Screen, Ref-All-Home then click the Machine Cood's for "no red outline state", then Zero XYZ.
This is easy to get into if you say yes to Fixture Offset Save Yes/No after shutting down Mach.
Hope this is It, Chip
Tried to Skype you no one home.
