Hello Guest it is October 17, 2026, 07:07:36 AM
Author Topic: X Weirdness  (Read 12392 times)
X Weirdness
« on: February 11, 2008, 12:22:55 PM »
Ok I am running a gantry system 4 800oz motors and 4 gecko 203v's, rack and pinion gear reduction via timing belts on all axis, recently the machine stopped cutting round circles, there is no backlash, but if i cut a 4x4 square my x=4" and my y=3.98 it's always off by 0.02 so i figure i can't be missing steps because it's always 0.02 i tried increasing the amount of steps but then i end up hitting my x limit on a tool change, which is weird, because i thought if i increased the steps then reset everything and homed if i move 10 inches left then right the same amount of steps should be sent.....
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: X Weirdness
« Reply #1 on: February 11, 2008, 01:58:31 PM »
Hi, Chrispol
Yes, So is X moving 10+ - accurate now, Have you tried resetting the tool change position a little.
Thanks, Chip
Edit: GLUE will do it Every Time, U--G.
« Last Edit: February 11, 2008, 02:33:46 PM by Chip »
Re: X Weirdness
« Reply #2 on: February 11, 2008, 02:22:25 PM »
Well seems mdf dust + linear bearing + grease = glue !
Unliked my drive unit from the x axis and couldn't move the motor, ripped it all apart glued bearings!
ugh!
