Hello Guest it is October 25, 2026, 04:27:29 AM
Author Topic: 24000 RPM to = 10 vdc from the Campbell combo board  (Read 11815 times)
« on: February 03, 2008, 10:36:03 PM »
Hey Guys.
I need 24000 RPM to = 10 vdc from the Campbell combo board. At this point 13000rpm = 10 vdc.  What do I change? Is this done on the new spindle config page?
Thanks. Russ.
Offline TonyP
  •  132 132
Re: 24000 RPM to = 10 vdc from the Campbell combo board
« Reply #1 on: February 05, 2008, 01:41:37 PM »
Russ,
check your pulley settings. Assuming you have pulley 1 set, set the max speed as 24000 or a bit higher, ratio 1. That will probably get you into the right sort of area.
Tony
