Hello
Guest
it is
October 25, 2026, 03:40:34 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
24000 RPM to = 10 vdc from the Campbell combo board
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: 24000 RPM to = 10 vdc from the Campbell combo board (Read 11812 times)
foprototype
3
on:
February 03, 2008, 10:36:03 PM »
Hey Guys.
I need 24000 RPM to = 10 vdc from the Campbell combo board. At this point 13000rpm = 10 vdc. What do I change? Is this done on the new spindle config page?
Thanks. Russ.
Logged
TonyP
132
Re: 24000 RPM to = 10 vdc from the Campbell combo board
Reply #1 on:
February 05, 2008, 01:41:37 PM »
Russ,
check your pulley settings. Assuming you have pulley 1 set, set the max speed as 24000 or a bit higher, ratio 1. That will probably get you into the right sort of area.
Tony
Logged
Print
Pages:
1
Go Up
« previous
next »
