Hello Guest it is November 25, 2026, 02:19:55 AM
Author Topic: tangential movement  (Read 14629 times)
sigmadane
tangential movement
« on: April 23, 2006, 11:04:31 AM »
   Hi there
  I was wondering if you could help me with a problem i have with a project.
  I want the tool axis(A axis) to move in a tangential route in relation to the x-y plane movement vector.
  I think this is programmed in the designed section(ex Autocad???).Or not?Is there any specail G-code for this function?
  I would appreciate any assistance.
    Thanks.
    Steve
Re: tangential movement
« Reply #1 on: April 23, 2006, 05:19:32 PM »
Hello Steve there is a setting under "settings" page where you can turn on tangential control. This will turn the A axis as the machine moves around the file...
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: October 16, 2007, 11:37:24 AM »
Did you ever get this to work?
