Hello Guest it is November 01, 2026, 01:01:22 PM
Author Topic: not generatig a contious cutting path.  (Read 22712 times)
« on: April 20, 2006, 12:57:13 AM »
Hello,
I am trying to generate  g code of an escape wheel for a homemade clock.  The escape wheel is similar to a gear but the teeth are slender and slanted. The problem is that the g-code that is generated has" z moves" between each tooth and it jumps around between  theeth.  One thooth of the gear will get cut, then the z moves up and moves ahead past the next tooth, cuts back to the tooth that just got skipped , and so on.......
Re: not generatig a contious cutting path.
« Reply #1 on: April 20, 2006, 03:14:42 PM »
I think there is a gap from line to line... This will cause the problems that you are seeing. Could you please send me the file and I will check to see if this is the problem.
Thank you
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: April 20, 2006, 11:27:57 PM »
Hi Brian,
Here is the the dxf file and the Gcode that Lazy cam is out putting.
Jose.
« Reply #3 on: April 21, 2006, 11:33:49 AM »
Thank you for the test files ! I will have a look at them as soon as I can.
www.machsupport.com
« Reply #4 on: April 23, 2006, 05:24:30 PM »
The arcs for the tips of the gears overlap the lines that they should be connected to. You need to clean up your drawing so that all the endpoints meet.
« Reply #5 on: April 23, 2006, 06:43:05 PM »
Gerry thank you for looking at that. I have been working on Gerber files and have not had the time to look at that other file (Hard to change once you are started on a bit of code...)
www.machsupport.com
« Reply #6 on: April 29, 2006, 12:35:11 PM »
Hey Guys,
Don't  Know how I overlooked that over lap.
Thanks for your help.
Jose.
