Hello
Guest
it is
November 01, 2026, 12:17:36 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
G-Code, CAD, and CAM
LazyCam (Beta)
not generatig a contious cutting path.
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: not generatig a contious cutting path. (Read 22710 times)
jguillen
28
on:
April 20, 2006, 12:57:13 AM »
Hello,
I am trying to generate g code of an escape wheel for a homemade clock. The escape wheel is similar to a gear but the teeth are slender and slanted. The problem is that the g-code that is generated has" z moves" between each tooth and it jumps around between theeth. One thooth of the gear will get cut, then the z moves up and moves ahead past the next tooth, cuts back to the tooth that just got skipped , and so on.......
Brian Barker
3,860
Re: not generatig a contious cutting path.
Reply #1 on:
April 20, 2006, 03:14:42 PM »
I think there is a gap from line to line... This will cause the problems that you are seeing. Could you please send me the file and I will check to see if this is the problem.
Thank you
Brian
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
jguillen
28
Reply #2 on:
April 20, 2006, 11:27:57 PM »
Hi Brian,
Here is the the dxf file and the Gcode that Lazy cam is out putting.
Jose.
Brian Barker
3,860
Reply #3 on:
April 21, 2006, 11:33:49 AM »
Thank you for the test files ! I will have a look at them as soon as I can.
www.machsupport.com
ger21
6,295
Reply #4 on:
April 23, 2006, 05:24:30 PM »
The arcs for the tips of the gears overlap the lines that they should be connected to. You need to clean up your drawing so that all the endpoints meet.
Brian Barker
3,860
Reply #5 on:
April 23, 2006, 06:43:05 PM »
Gerry thank you for looking at that. I have been working on Gerber files and have not had the time to look at that other file (Hard to change once you are started on a bit of code...)
www.machsupport.com
jguillen
28
Reply #6 on:
April 29, 2006, 12:35:11 PM »
Hey Guys,
Don't Know how I overlooked that over lap.
Thanks for your help.
Jose.
Print
Pages:
1
Go Up
« previous
next »
