Hello
Guest
it is
November 11, 2026, 11:00:33 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
setting kernal speeds on Mach 3
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: setting kernal speeds on Mach 3 (Read 12972 times)
richyrich212
36
on:
December 12, 2007, 04:49:30 PM »
Hello all,
Can someone tell me where to get the kernal speed in mach3 ?? When the system was installed the kernal speed was set to 25k but I would like to change that value.
Also in the motor tuning field I can only set my velocity as high as 412. in /min. mach will not let me go any faster?? Is there a way to overcome this ??
thanks in advance for any info !!
Logged
Carnoustie, Scotland
Re: setting kernal speeds on Mach 3
Reply #1 on:
December 12, 2007, 05:17:41 PM »
Setting the kernel speed higher will allow faster velocity, that is if your motors/drives can handle it. You will find the kernel speed from the Config menu then the Ports and Pins page, right under where you set your port address.
Last Edit: December 12, 2007, 05:19:43 PM by Hood
Logged
richyrich212
36
Reply #2 on:
December 12, 2007, 05:28:23 PM »
Hood,
thanks for the info. that was a great help !!!
Logged
Bear
15
Reply #3 on:
December 15, 2007, 05:34:12 AM »
Merry Christmas,
Could help me with kernal speed as Im not much up with computers.
Bear,
thanks
Logged
Reply #4 on:
December 15, 2007, 05:47:42 AM »
What are you needing help with?
Logged
Print
Pages:
1
Go Up
« previous
next »
