Hello Guest it is October 14, 2026, 11:39:19 PM
Author Topic: Simple Wiring Problem ???  (Read 9976 times)
« on: December 03, 2007, 07:09:16 AM »
Greetings,
   Not sure if I should post here or in third party forum. Please advise for future posts.
I have a cnc4pc bob and am unsure of how to connect an Interinar and an Automation Direct driver to it.
The bob terminals are ....    in#   5v   in#   5v   in#   5v   in#.... and so on , 5v being commom.
The Interinar driver terminals are....     GND     /    STEP    /     DIR     /     ENABLE
The other driver is Automation Direct with terminals..       Step+  Step-    /   Dir+  Dir-   /     Enable+  Enable-
The bob looks to be OK the way it is for the AD driver but looks like I may have to move the jumper to 0v common for the Interinar driver.
I'm unsure and do not want to take any chances.
Any help would be much appreciated.
« Last Edit: December 03, 2007, 07:58:41 AM by Overloaded »
Re: Simple Wiring Problem ???
« Reply #1 on: December 03, 2007, 08:30:54 PM »
All is good. I took a shot at it. With a little help from cnc4pc it works just fine.....NO SMOKE !
The "Enables" on this set-up are opposite of what I expected though.
Making chips soon.
Regards
« Reply #2 on: December 05, 2007, 04:04:43 PM »
Well, I can only wish you luck..
My mill is dead and I have no manuals for the wiring :(
I have purchased alot of the PC to CNC hardware already, but I wanted to use my servo motors, and I cannot find schematics to the motors :(
I can wire if I have a path... no path :(
