Hello Guest it is November 11, 2026, 01:30:55 PM
Author Topic: MachCloud point viewer program  (Read 198998 times)
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
« on: November 23, 2007, 07:51:42 AM »
Hi Guys, this is the start of the machcloud program, only a viewer at the moment, but will become our
meshing program..
Art
« Last Edit: November 27, 2007, 12:44:42 PM by ART »
Re: MachCloud point viewer program
« Reply #1 on: November 25, 2007, 12:11:06 PM »
Art,
I'd like to see the format of a typical point cloud file.  Can you post as example?
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #2 on: November 25, 2007, 06:48:42 PM »
Hi, David
Hears what it will load now,
 -1.9005 , 0.3834 , 2.9396
 -1.8850 , 0.3851 , 2.9465
 -1.8732 , 0.3849 , 2.9456
 -1.0162 , 0.8038 , 4.7026
Hopefully later it will load  X -1.0162 , Y  0.8038 , Z 4.7026  That Mach can generate also.
The viewer sorta takes over all my Txt files as Point Cloud's.
Hope this Helps, Chip
« Reply #3 on: November 25, 2007, 07:09:41 PM »
I noticed that it takes over the txt files.  That's easy to fix though.  Just right click on the txt file and choose "open with", then "notepad".
Offline Chip
  •  2,055 2,055
« Reply #4 on: November 25, 2007, 07:39:36 PM »
Hi, David
Yea but you have to do it every time you open a text file so it seems.
I'm sure it'll get sorted out soon, Some new .??? extent.
It's just nice to have viewer without all the CAD Work though.
Thanks, Chip
Offline Chip
  •  2,055 2,055
« Reply #5 on: November 25, 2007, 08:19:48 PM »
Hi, Art
Your Prop scanned some time ago looks pretty good in the Viewer.
Hears the file, http://www.machsupport.com/forum/index.php?action=dlattach;topic=1196.0;id=803
Thanks, Chip
« Last Edit: November 25, 2007, 08:24:52 PM by afn09556 »
« Reply #6 on: November 25, 2007, 09:07:35 PM »
Hi, David
Thanks, Chip
Look for "open with"..."choose new program"...
At this point you get a list of programs and the opportunity to make it permanent.
Offline Chip
  •  2,055 2,055
« Reply #7 on: November 25, 2007, 09:25:44 PM »
Hi, David
This is true Right click on file sel Properties then Change to notepad ect...
BobCad dose the same thing as do many other prog's when you install updates.
Thanks, Chip
Offline ART
  •  1,703 1,703
« Reply #8 on: November 27, 2007, 12:45:59 PM »
Hi Guys:
 Here is a newer machCloud program..
Itallows for some pruning and cloud decimation as cleanups..
Art
Offline Chip
  •  2,055 2,055
« Reply #9 on: November 28, 2007, 11:47:38 AM »
Hi, Art
Could you add the "X -1.0162 , Y  0.8038 , Z 4.7026", Format
That Mach can generate with Probing.
How dose the Decimate Cloud function work.
Thanks, Chip
« Last Edit: November 28, 2007, 11:52:50 AM by afn09556 »
