Hello Guest it is November 13, 2026, 05:29:51 PM
Author Topic: servo motors  (Read 11580 times)
servo motors
« on: November 20, 2007, 08:16:29 PM »
if the servo motor stop because of over torque the the program stop to?
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: servo motors
« Reply #1 on: November 20, 2007, 09:12:35 PM »
Hi, Luther
Only if you have the servo error/trip fed back to Mach, Config, Ports&Pins, Inputs, "E-stop", 5 volts Max or gnd., Tied into your E-stop in some way.
Probably other way's also.
Hope this Helps, Chip
Re: servo motors
« Reply #2 on: November 20, 2007, 09:23:17 PM »
hello afn09556, so mach don't know if the servo stops are not without going through the e-stop
Offline Chip
  •  2,055 2,055
Re: servo motors
« Reply #3 on: November 20, 2007, 09:44:27 PM »
Hi, Luther
Mach has no way to now with out a signal to stop.
Thanks, Chip
Re: servo motors
« Reply #4 on: November 21, 2007, 03:24:15 PM »
If your drives have a fault signal output then you can put this in to Mach  as  Input 1, then on the General Config page at the lower left you choose the Program Safety Lockout option. If your drives fault then Mach will see input 1 and will stop.
