Hello
Guest
it is
November 17, 2026, 11:54:25 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
servo motors
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: servo motors (Read 11594 times)
luther
8
servo motors
on:
November 20, 2007, 08:16:29 PM »
if the servo motor stop because of over torque the the program stop to?
Logged
Chip
2,055
Gainesville Florida USA
Re: servo motors
Reply #1 on:
November 20, 2007, 09:12:35 PM »
Hi, Luther
Only if you have the servo error/trip fed back to Mach, Config, Ports&Pins, Inputs, "E-stop", 5 volts Max or gnd., Tied into your E-stop in some way.
Probably other way's also.
Hope this Helps, Chip
Logged
luther
8
Re: servo motors
Reply #2 on:
November 20, 2007, 09:23:17 PM »
hello afn09556, so mach don't know if the servo stops are not without going through the e-stop
Logged
Chip
2,055
Re: servo motors
Reply #3 on:
November 20, 2007, 09:44:27 PM »
Hi, Luther
Mach has no way to now with out a signal to stop.
Thanks, Chip
Logged
Carnoustie, Scotland
Re: servo motors
Reply #4 on:
November 21, 2007, 03:24:15 PM »
If your drives have a fault signal output then you can put this in to Mach as Input 1, then on the General Config page at the lower left you choose the Program Safety Lockout option. If your drives fault then Mach will see input 1 and will stop.
Logged
Print
Pages:
1
Go Up
« previous
next »
