Hello
Guest
it is
November 13, 2026, 10:37:17 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Problem with MACH3 Mill
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Problem with MACH3 Mill (Read 9394 times)
manoj2s
10
on:
November 16, 2007, 12:47:08 AM »
Hi
I am using MACH3 for hobby cnc stepper motor application.
Since last time i find problem with MACH mill like i can run motor in only forward direction when use reverse direction key then only DRO is updating but motor is not moving.
Could you please advice,
Regards
Manoj
Logged
Chip
2,055
Gainesville Florida USA
Re: Problem with MACH3 Mill
Reply #1 on:
November 16, 2007, 02:09:37 AM »
Hi, Manoj
In config, ports & pins, motor outputs, change the "Direction Active Low" to opposite State.
If your motors run backwards, Config, Home & limits, Change the "Reversed", State.
Hope this Helps, Chip
Logged
Print
Pages:
1
Go Up
« previous
next »
