Hello Guest it is October 25, 2026, 02:15:42 AM
Author Topic: Cutting Circles  (Read 57961 times)
Re: Cutting Circles
« Reply #30 on: February 01, 2009, 08:26:13 AM »
lemo,
Have no answer, curious, and just some thoughts.
From a numbers point of view, if you divide a 8" circle into 50 equal parts the length between
two parts is 1.0026" and if it was a true circle with just one flat you would have a change in diameter of
.0315" ( 1/32" ).
What are you cutting?
Can you post the Lazycam, cut2d code that you tested with?
What version of Mach and SS plug-in are you using?
Offline lemo
  •  135 135
Re: Cutting Circles
« Reply #31 on: February 02, 2009, 06:27:28 PM »
ITS ALL MACH3's FAULT!!!  >:D
Well... cough cough.... NOT...  ::)
Today the problem was found... The Z Axis carriage is pulled around on the gantry using a timing belt and that is linked to the carriage with a little AL block which also tightens the belt. Two 1/4 inch screws are used to lock that block onto the carriage. All was tight... but... the holes were bottomed out... HA! The darn thing was tight enough that there was no indication of a fault while manhandling it. But when the 250lbs gantry stops or accelerates quickly, then it slipped a tiny bit, thus leading to the symptoms of backlash. The holes have been set deeper, the screws tightened tighter. And the friggin flats have taken a vacation. Circles are nice and round now.
Flats -> some sort of backlash or slippage of some kind.
Next time I will rivet, braze, weld, glue, and fuse that bugger to the parts.... Did I forget a method?
Lemo
Cut five times and still to short...
Re: Cutting Circles
« Reply #32 on: February 02, 2009, 10:49:03 PM »
Mach 1 - Lemo 0 ;)
Glad you figured it out, now what are you going to do for fun?  :)
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Cutting Circles
« Reply #33 on: February 03, 2009, 06:10:13 AM »
Nice one, you will not forget that one in a rush.
Graham
