Hello
Guest
it is
November 03, 2026, 08:02:40 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Cutting Circles
« previous
next »
Print
Pages:
1
2
3
4
Go Down
Author
Topic: Cutting Circles (Read 58415 times)
vmax549
Re: Cutting Circles
Reply #10 on:
November 13, 2007, 02:04:34 PM »
How did you program the code to machine the circle
Logged
Rkjohn
65
Re: Cutting Circles
Reply #11 on:
November 13, 2007, 02:14:56 PM »
Ran my DXF file thru LazyCam.
Logged
Graham Waterworth
2,785
Yorkshire Dales, England
Re: Cutting Circles
Reply #12 on:
November 13, 2007, 02:29:28 PM »
What diameter is your circle and how long are the flats?
Graham.
Logged
Rkjohn
65
Re: Cutting Circles
Reply #13 on:
November 13, 2007, 02:34:57 PM »
Had 2 - 1/2" circles & they turned out to be rounded squares. Had a 1 1/2" circle & it was better but had some small flats. Useing an 1/8" bit.
Logged
Carnoustie, Scotland
Re: Cutting Circles
Reply #14 on:
November 14, 2007, 02:29:44 AM »
Use the circle cutting wizard and see what the circles turn out like.
Logged
Rkjohn
65
Re: Cutting Circles
Reply #15 on:
November 14, 2007, 04:51:55 PM »
I can't figure out how to use the wizard. Here is the extracted code from the Gcode for the 1/2" circle. It looks good to me. Maybe you can see something.
N1450 G0 Z0.5000
N1455 X7.2003 Y2.2248
N1460 Z0.1000
N1465 G1 Z-0.2500 F30.00
N1470 G2 X7.5000 Y2.3750 I0.1122 J0.1502 F15.00
N1475 X7.2003 Y2.2248 I-0.1875 J0.0000
N1480 G0 Z-0.1500
N1485 G1 Z-0.5000 F30.00
N1490 G2 X7.5000 Y2.3750 I0.1122 J0.1502 F15.00
N1495 X7.2003 Y2.2248 I-0.1875 J0.0000
N1500 G0 Z-0.4000
N1505 G1 Z-0.7500 F30.00
N1510 G2 X7.5000 Y2.3750 I0.1122 J0.1502 F15.00
N1515 X7.2003 Y2.2248 I-0.1875 J0.0000
Ron
Logged
Rkjohn
65
Re: Cutting Circles
Reply #16 on:
November 14, 2007, 05:13:43 PM »
I took out the 1 1/2" circle, put it into Mach3Mill & then loaded it into LazyCam. The top & bottom look OK but the right & left sides do not & thats where I had the problems with being off. Here is the code.
N5 (File trimer hold mold and top bottom z axis )
N10 (Default Mill Post)
N15 (File Posted in Mill Mode)
N20 (Tuesday, November 06, 2007)
N25 G90 G80 G40 G91.1
N30 M5 M9
N35 M6 T1(TOOL Change)
N40 G43 H1
N45 G0 Z0.5000
N50 X1.0767 Y0.5987
N55 Z0.1000
N60 M3
N65 G1 Z-0.2500 F30.00
N70 G2 X2.8750 Y1.5000 I0.6733 J0.9013
N75 X1.0767 Y0.5987 I-1.1250 J0.0000
N80 G0 Z-0.1500
N85 G1 Z-0.5000
N90 G2 X2.8750 Y1.5000 I0.6733 J0.9013
N95 X1.0767 Y0.5987 I-1.1250 J0.0000
N100 G0 Z-0.4000
N105 G1 Z-0.7500
N110 G2 X2.8750 Y1.5000 I0.6733 J0.9013
N115 X1.0767 Y0.5987 I-1.1250 J0.0000
N120 G0 Z0.5000
Ron
Logged
docltf
354
Re: Cutting Circles
Reply #17 on:
November 15, 2007, 02:53:45 AM »
rkjohn
if you can run a .250 end mill this cuts a 2.5 circle. it will make two rough passes and one finish pass.
g00 g20 g91.1
g00 z.100
g00 x-.975 y.975
g01 z-.250 f25
g02 x-.975 y.975 i.975 j-.975
g01 z-.500
g01 x-.9723 y.9723
g02 x-.9723 y.9723 i.9723 j-.9723
g00 z.100
g00 x0 y0
m30
Logged
Rkjohn
65
Re: Cutting Circles
Reply #18 on:
November 15, 2007, 02:52:21 PM »
I changed your code to cut 1/4" & slower. Here is a pic of how it turned out.
I must have some backlash but I can not measure it with a dial.
I also tried to load the gcode into LazyCam & had an unrecoverable error.
Logged
Chip
2,055
Gainesville Florida USA
Re: Cutting Circles
Reply #19 on:
November 15, 2007, 03:27:31 PM »
Hi, Rkjohn
Have you checked if your in CV Mode, May be causing the Problem, Config, General Config, "Motion Mode", set to Exact Stop.
Thanks, Chip
Logged
Print
Pages:
1
2
3
4
Go Up
« previous
next »
