Hello Guest it is October 25, 2026, 12:28:26 PM
Author Topic: Mach3 Not saving the current tool number at shut-down  (Read 23302 times)
« on: December 29, 2022, 03:12:16 AM »
Hi Everybody,
I run Mach3 on an OMNI router with a ATC spindle. All works fine except the system function, current tool number, is not stored during shut-down. I assume all system functions would be saved in the XML configuration file? What am I doing wrong?
Kind regards and thank you
Danie
Offline TPS
  •  2,627 2,627
Re: Mach3 Not saving the current tool number at shut-down
« Reply #1 on: December 29, 2022, 05:17:22 AM »
try:
Config -> General Config -> Axis DRO properties -> Tool Selection persistent
« Reply #2 on: December 29, 2022, 05:56:20 AM »
Thank you very much!
Regards Danie
