Mach Discussion => General Mach Discussion => Topic started by: DanieGouws on December 29, 2022, 04:12:16 AM
Hi Everybody,
I run Mach3 on an OMNI router with a ATC spindle. All works fine except the system function, current tool number, is not stored during shut-down. I assume all system functions would be saved in the XML configuration file? What am I doing wrong?
Kind regards and thank you
Danie
try:
Config -> General Config -> Axis DRO properties -> Tool Selection persistent
Thank you very much!
Regards Danie
