Hello Guest it is October 20, 2026, 11:40:36 PM
Author Topic: Y moving in opposite direction  (Read 26045 times)
« on: September 17, 2022, 02:39:33 AM »
Hi Group, my Y is moving towards me rather than away - I must have touched something I think?  Any help to get it back to normal please !
Re: Y moving in opposite direction
« Reply #1 on: September 17, 2022, 05:18:52 AM »
 go to config/ports and under motor outputs  either check or uncheck the dir box for the y axis.
Regards
Charlie M.
« Reply #2 on: September 17, 2022, 06:27:54 AM »
Thankyou.  I noticed it continues to move to negative rather than to the positive, when going from negative Y to positive Y........any help????Please!!
« Reply #3 on: September 17, 2022, 06:32:38 AM »
is this when you are jogging the machine? if so go to config/hotkeys and set Y  + and - keys.
Regards
Charlie M.
« Reply #4 on: September 17, 2022, 07:01:53 AM »
Thankyou. Its when it is reading the code running a program....the code says Y15 , but it moves from Y -10 to more negative Y, rather than moving to positive.....
« Reply #5 on: September 17, 2022, 08:15:14 AM »
Then you have to set the y dir either active high or active low.
Regards
Charlie M.
