Hello
Guest
it is
September 16, 2026, 11:40:02 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Y moving in opposite direction
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Y moving in opposite direction (Read 25911 times)
anthony.zulli
25
on:
September 17, 2022, 02:39:33 AM »
Hi Group, my Y is moving towards me rather than away - I must have touched something I think? Any help to get it back to normal please !
Logged
Charlie_M
189
Re: Y moving in opposite direction
Reply #1 on:
September 17, 2022, 05:18:52 AM »
go to config/ports and under motor outputs either check or uncheck the dir box for the y axis.
Logged
Regards
Charlie M.
anthony.zulli
25
Reply #2 on:
September 17, 2022, 06:27:54 AM »
Thankyou. I noticed it continues to move to negative rather than to the positive, when going from negative Y to positive Y........any help????Please!!
Logged
Charlie_M
189
Reply #3 on:
September 17, 2022, 06:32:38 AM »
is this when you are jogging the machine? if so go to config/hotkeys and set Y + and - keys.
Logged
Regards
Charlie M.
anthony.zulli
25
Reply #4 on:
September 17, 2022, 07:01:53 AM »
Thankyou. Its when it is reading the code running a program....the code says Y15 , but it moves from Y -10 to more negative Y, rather than moving to positive.....
Logged
Charlie_M
189
Reply #5 on:
September 17, 2022, 08:15:14 AM »
Then you have to set the y dir either active high or active low.
Logged
Regards
Charlie M.
Print
Pages:
1
Go Up
« previous
next »
