Hello Guest it is October 25, 2026, 02:34:13 AM
Author Topic: reverse axe direction  (Read 8723 times)
Offline frapo
  •  11 11
« on: July 12, 2022, 02:42:40 AM »
Hi
how can i reverse the axe direction for my mini lathe.
The -z and the +z runs the same direction and also the -x and the +x runs the same direction.
Re: reverse axe direction
« Reply #1 on: July 12, 2022, 03:03:38 AM »
Hi
Go to Configure - Control - Motors and down, between Backlash and Enable delay is a tick for reverse.
« Reply #2 on: July 12, 2022, 03:04:27 AM »
Or you mean about keyboard control??
If yes go to Configure - Plugins - Keyboard and change there.
« Last Edit: July 12, 2022, 03:06:35 AM by Greekart »
Offline frapo
  •  11 11
« Reply #3 on: July 12, 2022, 03:14:29 AM »
Just try this and no change.
« Reply #4 on: July 12, 2022, 03:17:57 AM »
What controller you use, check the controller plugin it may need to change it there. Or maybe you have something wired wrong and work only one direction..
Offline frapo
  •  11 11
« Reply #5 on: July 12, 2022, 04:01:03 AM »
In mach3 all was working fine,i use  uc100 motion controller.
Offline frapo
  •  11 11
« Reply #6 on: July 12, 2022, 05:19:05 AM »
Solved,my direction pin numbers were wrong, sorry for the trouble greekart thanks anyway.
