Hello Guest it is October 24, 2026, 08:13:36 PM
Author Topic: MACH4 Manual Screen  (Read 7243 times)
MACH4 Manual Screen
« on: May 29, 2022, 04:30:35 PM »
Hi
I have installed the Manual Lathe Screen (Mach4_Manual_Lathe.m4prof).
If I switch from AUTO screen to Manual screen, there is always
the blue toolpath window overlayed as shown in attached pic
BR
Gerhard
Offline frapo
  •  11 11
Re: MACH4 Manual Screen
« Reply #1 on: July 13, 2022, 12:06:44 PM »
And how do you install this screen?
« Reply #2 on: July 13, 2022, 12:20:27 PM »
Hi
have problem solved
in toolpath config was a checkbox
„use frame“ or so
If I uncheck it, the toolpath in the manual screen was disappeared
BR
Gerhard
Offline frapo
  •  11 11
« Reply #3 on: July 13, 2022, 12:26:40 PM »
But how do install this screenset or screen,
« Reply #4 on: July 13, 2022, 05:47:13 PM »
Typically to change a screen set requires that Mach4 is running and with the <View> tab choose the <Load Screen> item and chose from the available screen sets. If you select a new screen set
when you shut down Mach your screen set preference will be updated courtesy of the ScreenUnLOad script.
Second way to do it is to create a new profile whereon you can select a particular screen set.
